Showing results forΒ
Search instead forΒ
Did you mean:Β
Underlines under text? what does it mean?
in the new ST8 callout properies. when you have the %DI for example, why is it underlined?
Hi It's simple! πŸ˜‰ You can use format codes for those "st...
Hi
It's simple! πŸ˜‰ You can use format codes for those "strings" (see below "active" format button)!
BR,
Imics
Re: Hi It's simple! πŸ˜‰ You can use format codes for those "st...
sorry, don't know language that's in
Here is a short video about "underline text":
You can see here, that how easy to set dual units.
BR,
Imics
