Undo Q
Not applicable
I'm getting comfortable with the 2D Model page so I decided to go back and
modify my first drawings to utilize this feature. I copied the drawing from
Sheet1 to the 2D model sheet, but the paste put the drawing where I could
not see it (I was zoomed in to the wrong area) so I pasted three times
before I saw where it pasted. I have already deleted the original and now I
can't "Undo" the paste and I have three copies all on top of each other.
Is there a way out of this? If not it is not a big deal. I have a copy of
this drawing at another location to recover from.
Tim
Re: Undo Q
Not applicable
Hi Tim,
I'm not sure there is an easy way to delete two of the three copies. When you pasted
the first one if you would have clicked on the "Fit" button it would have been visible
for you. Probably not what you wanted to hear but maybe one of the experts knows
of a way to delete the two unwanted copies.
Ed
>I
>Thanks,
>Tim
Re: Undo Q
Not applicable
I finally recovered from a saved file. What a goof! Yes, "fit" sure
helps find stuff.
Tim
Ed Kadlec wrote:
> Hi Tim,
> Ed
>> I
>> Thanks,
>> Tim
