Untrim surface
Is there anything simillar to this?
https://www.youtube.com/watch?v=bta6n2yYZpM
I want to do it in SE, But don't know how.
Tiago
4 REPLIES 4
Betreff: Untrim surface
Hi @TiagoFigueiredo
You can do this - if the original surface will have those informations - using the "Copy Surface" command
You will find an option there which You have to turn on
"Remove External Boundaries"
Wolfgang
Uauu...
I was really lost with CATIA, i've done much with it, lots of automation, lots of templates, and so on. It's an really expensive software with lack of user interface improvment for years.
Tiago
Hi @TiagoFigueiredo
and, has the Copy Surface command helped YOu to do what You wanted?
Wolfgang
Sorry, yes it did.
Smiley Happy
Tiago
