Up to what Autocad version can ST6 open?
I can't seem to open a dwg file in free2D ST6 but can do so in a competing 2D freeware. The help file says (version 12 - current version) but what does current version mean for free2D ST6?
Tim
For the responsibility, an Engineer's pay is a joke.
Re: Up to what Autocad version can ST6 open?
Hi Tim Solid Edge ST6 support opening AutoCAD files Version 12- Current. Current means the version of AutoCAD available at the time Solid Edge ST6 was delivered. In this case AutoCAD 2013. However the format of AutoCAD did not change in 2014, so you should not have a problem opening file saved in this version either.
If you would like, I can take a look at your AutoCAD file if you care to send it to Steve.Weatherwax@siemens.com?
Thank you Steve. I will send that AutoCAD file.
Tim
