Updating SQL server for insight
We are looking at updating from ST7 to ST8 and we are using Insight.
I believe that it's not a requirement to update the SQL server beyond 2008 R2, (although I remember a while ago it was said ST7 would be the last on SQL Server2008).
However I have to opportunity to future proof our installation, at least for a while.
Are there any pitfalls I should be aware of with regards to updating the SQL Server?
Basically my plan is;
Update the SQl Server.
Uninstall Insight Server ST7
Install Insight Server 2010 and Maintenance packs
Update the Clients to ST8 and Maintenance packs.
How hard can it be....... Right?
Cheers
Glenn
