Upgrade of ST6 Custom Files to ST7
Buying and using the Solid Edge since v7, I am bit embarased to aks, but I wish to do it quick and eficient.
Excluding my Solid Edge asm, par, psm and pwd template files, is there any quick guide / opinion to transfer all my custom settings from ST6 to ST7 such as ribbbon, radial menu, BoM draft tables and many more.
Sure my holes.txt should be reviewed with the new holes command structure etc.
Thanks in advance.
Milan
www.aaaengineering.com
Milan Wendl, MEngSc, P.Eng.
AAA Engineering, Canada
ST10, SolidWorks Premium 2018
Re: Upgrade of ST6 Custom Files to ST7
Good morning Milan,
Please see the 2 images that I have attached below. Go look for a folder in the "Customization" folder with the same name as your custom theme. In my case it is "THEODORE3". You simply just copy this folder to the "Customization" folder in the "Version 107" folder.
As for your reports, go check in File Locations where they are currently saved.
Theodore
Kind regards,
Theodore Turner
Siemens Genius Siemens Genius
Siemens Genius
With ST7, we have changed from using text files for holding hole information to using Excel spreadsheets.
We have provided a conversion utility to convert your old database files.  This utility is located here:
C:\Program Files\Solid Edge ST7\Custom\HoleDatabaseConverter\bin
Note that your installation path may be different if you changed it on install.
You might then drop your converted .xlsx files into your hole database folder, which by default is here:
C:\Program Files\Solid Edge ST7\Preferences\Holes
By so doing, you will have access to the 8 delivered databases in addition to your converted ones.
Hope this helps,
Steve
* Opinions are my own.
Steven Sheldon
Advanced Applications Engineer
Siemens PLM Software
* Opinions expressed are my own.
Honored Contributor
Honored Contributor
Attached is what Ally PLM sent out with the upgrade links. I found it helpful. I only lost some details of my custom expanded metal materials. The attached PDF helped me to remember the reports folder. That's a big one to capture for me, about 50 very detailed custom Annotation settings.
Hello Theodore, Steven and 12GAGE,
Thank you all for your prompt help and advise.
I really appreciate it.
Milan
Also, check the Solid Edge README.html file delivered with ST7. It has specifics on what was changed in ST7 in regards to settings controlled by templates as well as other information like the changes to the Hole database, and how legacy holes will be treated.  Gives you an idea what you may need to change/update before you deploy the new version.
Also, if you have your own templates stored somewhere that you use, make sure that when you get a new version and start using it (like ST7), make sure you open and save each of those templates in the new version.  This "upgrades" their internal database and keeps it from having to happen each time you create a new SE file.
http://Grundey.blogspot.com
Hello Ken,
Thank you very much for your help too.
Milan.
