Upgraded to 64-Bit XP can't open existing files
Not applicable
We upgraded our work stations to 64 bit cpu's and windows xp professional 64. Now
when we try to open any files created by the 32 bit machines we get the attached
error. We have tried both V19 and V20. Ant suggestions?
Re: Upgraded to 64-Bit XP can't open existing files
Not applicable
SE2D is 32 bit code, so are you running it in WOW64 (32 bit emulation mode)?
PellaKen
http://grundey.blogspot.com
"Andy Bancroft" wrote in message
news:475d9e42$1@bbsnotes.ugs.com...
> 64. Now
> attached
Not applicable
Not sure. How can you tell?
>PellaKen
>> 64. Now
>> attached
Not applicable
Don't know. I just know that it cannot be run natively as it is not a 64
bit app and has to run in the emulator. Not sure if it is automatic or you
have to specify it.
PellaKen
news:475dba10$1@bbsnotes.ugs.com...
>>mode)?
>>PellaKen
>>> professional
>>> 64. Now
>>> attached
Not applicable
It sounds like a bad install to me. I would uninstall Solid Edge, clean the
registry (ask other newsgroup folks how to do this) and reinstall and retry.
PS> Why in the world are you running a 64 bit OS if all you're doing is 2D
drafting?
DS
>>mode)?
>>PellaKen
>>> professional
>>> 64. Now
>>> attached
Not applicable
This is happening on multiple machines/installs.
Our workstations also run UGNX5 and were upgraded for this.
Solid Edge free2d will start a new file with out a problem.
It is just the files created by the 32 bit machines that we are unable to open.
Unfortunatley this includes all of our backgrounds, symbol files, existing drawings,
etc.
>drafting?
>DS
>>>mode)?
>>>PellaKen
>>>> professional
>>>> 64. Now
>>>> attached
Not applicable
Problem solved by installing 2.0 .NET framwork (x64) from microsoft.
Andy
>open.
>drawings,
>etc.
>>drafting?
>>DS
>>>>mode)?
>>>>PellaKen
>>>>> professional
>>>>> 64. Now
>>>>> attached
