Re: Using Alternate Assemblies is not friendly to use
Ya ... but not in alternative assembly mode ... Smiley Sad
I sugested this because ... Engineers like me ..(may be)
I start building a complex part (right side) and start a left part with more modification and extra functions ...
for sure the above mentioned is possible...
MfG -
Viv
@Imics, Why does the old mirror command work and the new command not work?
Bruce Shand
