Using Beginner Solid Edge
My 11 Year Grandson Is Interested In Doing Solid Edge,
We Are Working On The Micrometer And We Are Stuck On The Design Intent To Extrude The Main Body We Tried NumerousTimes To Show The Anvil.
We Are Missing A Step Someplace.
Any Thoughts
http://screencast.com/t/xzOnXGtnSJN
Thank You
GregoryLee
Re: Using Beginner Solid Edge
At first glance, it looks like you have made the cylindrical face (one with the hole in it) tangent to the face you are trying to move. Go back a few steps and make sure these faces are not tangent.
To Be Quite Frank With You...
I've Been Getting That Command...Here Of Resent. Basically I'll Just Redo That Part And Go Around That Command. I Do Not Even Know How This Command Even Works.
And With Your Terminology All French To Me.
Beg My Parden
GregoryLee
The hole feature was not concentric with the cylidrical face.Open the attached PDF file and follow the instructions.
