Using Parts From An Assembly
Is There A Video Tutorial On Using Parts From An Existing  Assembles.
I Have A Few Parts I Have In One Assembly To Use In Another Assembly
Greg
Re: Using Parts From An Assembly
Greg,
Those individual parts in that assembly reside on your computer, in a file directory....so just create your new assembly and add those parts as you want.....it is of no consequense to re-use them elswhere, untill you want to make design changes base on the way the new assembly developes....at which point you then need to use "replace with copy", give it a new name/number and alter accordingly.
