Using Parts into a New Assembly
I opened a new assembly out of another assembly. I've filed the parts into a temp file.
Now I'm at a point the parts I transferred are coming into the old assembly with a File Load Failure with all the parts I put into the new assembly.
I open the parts library send the part to assembly .asm , open up the new file under Temp set the part to Temp Close.
Thank You
Greg
