Using ST2 - Only ST4 above License Available???
We are currently using SolidEdge 2D ST2 (I know we need to look at upgrading!!).
How do I get a renewed license? I can see only ST4 or above on the download page?
Our license expires in 16 days.
Many thanks,
Paul
Re: Using ST2 - Only ST4 above License Available???
Paul,
Whatever you do go straight to ST7... if your're going to "upgrade" PLEASE go all the way!   ST7 will bring you so much more to work with.
And don't take this the wrong way, but if you're NOT using Synchronous, then why even bother upgrading. Again if you're "upgrading" then you truly need to make the jump.
My $.02
Bob
As far as licenses go you need to call your VAR or GTAC
