Using Threaded Line Strength To Create A Pattern
Start Drawing Description With Line Color, Pattern, Strength, Name Of Color. Using The Line Strength As A Focal Point... While Building A Part Through Background Image As A Pattern.
Adding A Building Material [2] To Match With A Touch Of Audio. More Power To The Part Within Using [ComaGonBearings]  {Many Moves}.
Comagon Bearings Is A System to Assist The Coordinate System On Positioning The Threaded Line While Designing Parts. Without Using Mechanical Fasteners.
As You May Notice At The End of The Video... Steering Wheel Is Present! Go Back To The Original Drawing, Restore, Copy And Move Sketch Outside Of Part, Set Inside Feature Library.
POST(Smiley Wink This Image Or Video May Be Different From The Original Document Part. Your Outcome May Differ [≡Alt752≡], Alt Is... Also Added To Assist Other Characters In This Keyboard.http://youtu.be/MuhMOiCKJp8
