Using the Scroll Wheel in Solid Edge - New Blog Article
Hello Edgers,
If you are using the scroll wheel on the mouse in Solid Edge for merely zooming or rotating the view then this article is for you. Be amazed by how much the tiny wheel can accomplish.
Read my latest article on the community blog:
And don't forget to join and also invite your colleagues to the Solid Edge User Group on FaceBook:
https://www.facebook.com/groups/solidedgeusers/
Tushar
