Using this free software to dimension other solid edge files
Not applicable
We have the version 20 solid edge software and wanted to use this 2d solid edge to just be able to pick dimensions, well something is blocked and can't figure out what it is, we can only pull up files from the version 20 solid edge, we cannot alter nor dimension. Please help.
Re: Using this free software to dimension other solid edge files
Not applicable
sorry
a have Solid Edge Free2D but now I can't possibility to use it.
I am not so good expert to remedy this.
English is a difficult too
Help me please if you can
Thank you
Not applicable
sorry
Thank you
Solid Edge 2D Drafting allows Solid Edge Draft files to be opened, but the Drawing Views created from 3D models are inactive. You can add notes and mark up the files, but you cannot dimension the drawing views. you can save the marked up files and reopen them in Solod Edge Draft. This is by design.
Rick B.
