Re: VErtical and horizontal curve
operation unsuccessful.
ST9
Conveyor and industrial equipment designer.
Giving SE a chance.
Thanks, we figured that one out to, but its weird that at full size it makes the curve, leaving out only the concave radius...As Bruce said if you change de radius to a line it works at full size.
ST9
Giving SE a chance.
Yes this is the Parasolid size limitation coming in here. The thing is over 1200 m long. You can get around this by splitting the model up into smaller chunks.
Couldn't you just do two extruded surfaces, intersecting each other, then do an intersection curve?
Solid Edge 2019
Windows 7 Professional
Nvidia K2200 & Intel Xeon
"You're doing it wrong"
Nope ,we really have to wrap for it to represent the real thing. Intersect doesnt give out the result needed.
ST9
Giving SE a chance.
