VMWare Horizon View with Solid Edge
A customer of ours is thinking in adopting VMWare's virtualization solution for worksations called "Horizon View" (details here) for their 10 Solid Edge seats. Customer said that VMWare has worked with Siemens while developing this solution.
Does any of you Solid Edge users had any experience with this solution? How is performance? How is overall experience compared to a local workstation?
Re: VMWare Horizon View with Solid Edge
Hello!
I have tested this environment.
Everything looks and feels good - exept solid edge... Some dialogs like the horizontal command bar, live rules or quick editing forms are a little bit laggy. It look some time to display them and also to hide them. Not very much but for a fast solid edge user this is very anoying.
Can not believe that this is a VMWare-Siemens-developed-solution.
Tested with vmware grid K2 grahpics (9.18.13.4725) and solid edeg ST6 x64 MP12.
regards,
Carsten
