Variable Table Purge?
I created one test item (see figure).
The problem is that this item is not deleted after use. ^^
Only the name is changed. (Why?)
How can I delete it?
5 REPLIES 5
Re: Variable Table Purge?
Here's one Purge Variables utility which you can check if applies to your case.
~Tushar Suradkar
fb.pngSolid Edge Users Facebook Group
Hi~ Tusbar
I would like to use this macro, but ...
Win10 environment or an error occurs.
It does not even run.
Sorry to hear that, I haven't had a chance to test it on Win10
What is the error ?
"Operation stopped."
Message appears. It is not executed at all.
No idea what's happening here, never used Windows 10
The only person who can help you and me with this is the one with Windows 10 + Solid Edge.
Let's keep fingers crossed.
