View-Override view-Texture On/Off One click??
Hi- Edge Users
I want to turn the Texture item On / Off with one click in each environment like title.
Can I make it On / Off with hidden shortcuts or API?
This is the label if you need it.
I usually turn off to use lightly.
It is easy to turn ON / OFF by one click when needed.
Re: View-Override view-Texture On/Off One click??
@Hclee
I'd suggest saving two View Styles - one with Textures ON and other with OFF and quickly switch between the two.
I could not find any API to create a macro or a button in the Customize list to drop on the Quick Access toolbar, but you can place the ViewStyle list on the Quick Access toolbar.
EDIT: I found the View Style list cannot be placed on the QATB
Note: I also found that the singular View Style command is different from its plural version View Styles
Hello tushar ..
At present, this method seems to be the best way.
Thank you.
