Re: View & Marup for ST10
Ok Thanks
I thinks we should contact with them.
thank you for giving me your time Sir
Hi @uk_dave
Hi @RaminSanakhan
but should it be not possible to do the same with DesignManager as it was done with the Revision Manager, even if all files are unmanaged?
Design Manager is a more modern Revision Manager with more functionallity but otherwise the same as the old RevisionManager.
Wolfgang
