View of a specified area
Not applicable
Have a good day,
I am Solid Edge 2D Drafting V20 user and I cannot create a detail view of a specified area. I referrred to tutorial and followed instrutions but I could not to create. Coul you tell me the procedure? Thanks.
Buen día,
Soy usuario de Solid Edge 2D Drafting V20 y no he podido crear un detalle de un área específica del dibujo. He seguido las instrucciones del tutorial pero aún así no he podido. ¿Podrían decirme el procedimiento adecuado? Gracias.
James
1 REPLY
Re: View of a specified area
Not applicable
James,
Detail views require a 2D Model View as input.
You create a detail view of a specific area of the 2D Model View.
You cannot create a detail view of 2d Geometry alone.
You can create your geometry in 2D Model.
Then place 2D Model Views of the geometry on the working sheet (Sheet1).
Once you have the 2D Model View you can create a detail view of that 2D
Model View.
I know this sounds difficult at first, but once you see what it is doing,
you will see the benefit.
All the geometry is in 2D Model. Any changes made to the geometry will
automatically show in the views.
Rick B.
