Views locked by blocks
Not applicable
I can't see the rest of my drawing, just the main repeated block (a hexagon).
I don't know exactly what I've done, but I can't see the drawing sheets or the 2D
Model sheets.
Is there a activation button I can click to get this drawing back?
-Andy.
www.continual-motion.com
Re: Views locked by blocks
Not applicable
Look under View in the top menu and see if Background Sheet and 2D model
sheet are unchecked.
David
"Andy Southern" wrote in message
news:48639503@bbsnotes.ugs.com...
> Hi,
> hexagon).
> the 2D
> Model sheets.
> Thanks,
> -Andy.
Not applicable
Andy,
What is the size of your blocks with respect to the working sheet? Sounds
like tte blocks are either off of the sheet or are large with respect to the
sheet.
On the working sheet, Hold down 'CTRL' and click Fit at the same time. This
will force fit to fit to the sheet regardless of the geometry on the sheet.
Once you have found the sheet, place some bogus geometry on the sheet and
then fit without 'CTRL'. This will fit what you had plus the geometry you
placed on the sheet. Now you should be able to figure out where your
original geometry is relative to the sheet.
Rick B.
