WRL or JT Export with Texture
have a question is it possible to export WRL or JT from Solid Edge to export with Textures?
Have done some try’s but have not found it out.
For this, I have used some additional Freeware.
An example how I hope it can be look like attached here.
Best Regards
Wolfgang
Test_Picture_HTML_JT2Go.PNGTest Picture HTML Export JT2Go
Re: WRL or JT Export with Texture
Wolfgang,
in the file "Solid Edge..../preferences/translators/sePVTrn.ini" you can enable the texture translation to a JT-file.
Just set: "Export Textures=1".
Not all export options are visible in the 'options' inside SE at the export.
Good luck
/Ulf
Siemens EMEA GTAC Support
Hello @Ulf_Eriksson,
let me say it positive yes the 0 hepls.
Now the little but if this is it all we can do with texture I let the hands off.
Best Regards
Wolfgang
