Web publisher
I´ve just downloaded and installed the new ST8 academic.
But I´ve found the html web publisher button in grey and no functioning.
Has it been disabled for this version?
3 REPLIES 3
Re: Aktivierung ST8 Academic
Hi there,
If you use the windows search tool for "License Utility" and press enter [assuming you only have one such licensing application on your system]....this will open the Solid Edge License Utility, where you can make your selection to "I have an Academic Code"...enter your license code & name of school....and Solid Edge should now run, as expected.
Solid Edge 2019 [MP8] Classic [x3 Seats - Cloud Enabled]
Community Manager
@verdos  Mike Brown sent me the 12-digit code that you received. We see the upgraded code had an error.  Mike and I will send you your correct ST8 code via email now.  Mike is working with Siemens IT/web team to correct the ST8 academic code generation.
We apologize for this inconvenience.
Laura
Ich habe das gleiche Problem mit dem Code, könnte man mir bitte auch den fehlerfreien Code zusenden, bitte.
