Weird drawing view copy
Dear SE users,
I have perhaps a weird handling of dragging drawing views in the same sheet.
When I select the view and drag it, it copies the selected view and the principal view.
I don't want this behaviour, so how do I set this behaviour off?
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
Re: Weird drawing view copy
If the view you are copying is a section view, auxilliary view or detail view it will create a new principal view over the top of the original. If you copy a pricipal view the original will not be copied.
I don't think there is any way to change this behaviour.
HP Z420 16GB RAM
Quadro K4000
ST10 MP3 on Windows 10 Pro 64.
The original view is a front view, I have created a section view from the front view.
Normally I can select each view and drag it to another location without a copy.
I had this problem never before, thats why I send this question.
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
Ok, the draft was corrupt.
New draft and no problem anymore.
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
