Welcome to the Solid Edge 45-day trial
As a quick introduction, I manage global marketing for Solid Edge and would like to first thank you for considering Solid Edge and downloading a 45-day trial version. Included in this version is award winning synchronous technology that has proven successful in helping companies like yours design better.
To help you maximize your trial feel free to ask questions or post tips in the forum—I think you will find the support here invaluable in learning more about Solid Edge. Also don’t forget that I’ll be sending you tips and tricks so check your email inbox every week. If you need help getting started, download this handy guide as it will walk you through how to get Solid Edge up and running and what your first steps should be. Also enclosed is “General Trial Test Plan” that can be used to guide your trial so you can explore the main areas of Solid Edge.
Thanks again, and design better.
Kris Kasprzak
Director, Solid Edge Marketing
Kris Kasprzak
