What happend to the sketches?
Honored Contributor
Honored Contributor
The sketches are no longer showing up in the modeling tree. Un-used sketches are now impossibles to grab to delete. Any suggestions?
This started when updating to ST7 MP? about 6 weeks ago. Can't update again until I finish a current project.
And another sketch related question. Can perpetual includes not be applied from objects from an upper level in the assembly tree?
Re: What happend to the sketches?
Not seeing this here, in both Sync PAR or PSM.....used sketches are still there.
Testing: Solid Edge 2019
Include options will allow you to uncheck the 'Maintain Links' box that makes your sketch element relationship 'Perpetual'
A picture or video would be a good way to show how your sketches are disappearing.
-Dylan Gondyke
