What is a Block Label and how do they differ to Blocks?
For example, what are some good examples of Block Labels being used?
I can't seem to find any information on them anywhere.
Thanks.
6 REPLIES 6
Betreff: What is a Block Label and how do they differ to Blocks?
Hi @User_Error
imagine a r+i scheme for example where You will have several instances of one and the same block  symbol but each of them has a different logical function.
Here You will use block labels to show different names/functions to any o them.
Or, take as example a block showing a motor symbol.
No we have ten of those motors, but each of them again has to be servered different in the sens of electrics.
Alle these situations are example for a different block label.
Wolfgang
@hawcad
I see.
So in the context of manufacturing drawings, I am currently using Blocks with Callouts that contain Properties on the drawing borders.
Example, using %{Created/@dd.MM.yy} as a callout, and Block that can be placed if a document is copied over and we need the date.
Would there be any benefit in using Block Labels on manufacturing drawings you've seen or are they meant mainly for R+I, electrical drawings etc?
Hi @User_Error
OK, fo such a usage I do not see many or even any situations for using a block label.
Block Lables IMHO are more in use for real 2D drawings and schematics, so the first idea I have got were R+I etc.
For backround sheet and drawing header I do not see the need of Block Labels.
Wolfgang
@hawcad
Okay thanks for the insight!
OK, guys, what does "r+i" refer to?
Edit: Oh, P&ID in English I presume?
Bruce Shand
Hi @bshand
sorry for falling into the familary but German shortcut, and Yes You are exactly right!
Wolfgang
