What's this icon?
from Assembly - Quick Pick?   a "dotted X"???
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
13 REPLIES 13
Re: What's this icon?
69 view - 0 replies...
I don't feel so ashamed anymore.
and trust me... I gave this a good hour of due diligence before posting...
Awaiting reply from GTAC.. Stay tuned
Matt Johnson
Teamcenter 10.1.7
@Johnson_BigMatt, I can't believe you don't know what that is!
http://Grundey.blogspot.com
We all know what it is, we don't want you to feel dumb. ;-)
Solid Edge 2019 & AutoCAD 2020 user
@Johnson_BigMatt And you call yourself a certified user?
Anyone who has been using Solid Edge for even a few hours can tell you that icon represents, uh, certain, uh, thing that, uh, deals with assemblies.  Duh.
____________________________________
--Scott Wertel, P.E.
Betreff: What's this icon?
Hi @Johnson_BigMatt
BTW what type of part/object is behind those entries?
Are these normal parts/psm/asm
Are these wire hareness, pipes, virtual components, ...
Wolfgang
Following
I saw the same thing yesterday in an ST8 assembly I was working on. I figured I'd come back and find the answer by now..........
ooooh, any ideas on your end?
Matt Johnson
Teamcenter 10.1.7
i've tried to dig in and investigate but i dont see anything special.
Note this is the Quick Pic dialog not the pathfinder...
I'm stumped.   I'll check into the IR Tomorrow... and then follow back up here.
Matt Johnson
Teamcenter 10.1.7
I found mine again today. It was for a sub within another sub-assembly. If I open that sub-assembly, the icon goes away. The icon came back when I closed the sub-assembly, and after repeating the open/close, the icon is now gone.
Maybe it has something to do with linking to another assembly? That's the only thing I saw, that "might" update after I closed the sub-assembly.
That probably made no sense to anyone other than Matt.............
