What would be the best way to convert SE files to revit for customer?
I have to supply RTA format(revit) files to our customers. What would be the best way to do this?
Nathan M. Gardner
https://www.etsy.com/people/NathanMGardner
Be sure to check out my work!!
Made in Maine Wood Carvings
Do you have a copy of Revit?  I believe it can read in SA...
Esteemed Contributor
Do you have a copy of Revit?  I believe it can read in SAT file V7 or earlier and then you can save out to RTA.  Solid Edge obviously cannot save to RTA but can save to SAT.  Aside from that I do not believe there will be any direct to Revit conversion tool, but you may find an IFC conversion tool if you search for it as this is a true BIM standard format.
Production: ST9 MP10
Testing: ST10 MP3
