Whats the best relation?
Honored Contributor
Honored Contributor
If I want to constrain a point to a plane (anyhwere in the plane), what's the best relation type to use?
If I want to constrain a line to a plane (any location or rotation), whats the best relation type to use?
I'm guessing connect is the only type that works for both cases.
Re: Whats the best relation?
I would use
point to plane: connect
line to plane: connect
Solid Edge ST10 & AutoCAD 2019 user
