When I click the "Take a Solid Edge Test Drive" to access tutorial PDF, nothing happens.
Where is the link you are clicking on?
MLombard
Retired
Re: Where is the link you are clicking on?
The link is on the first screen that appears when I start up the Solid Edge 2D Drafting (Free 2D)
I am clicking on the link that appears on the first screen of the Solid
Edge 2D Drafting (Free2d) application.
Not sure why the PDF file is not opening. Can you open PD...
Not sure why the PDF file is not opening. Can you open PDF files from Windows Explorer by double-clicking? Also, are your PDF files opening into Adobe Reader or a third-party PDF reader?
Without resolving why the PDF file is not opening from the Solid Edge screen, you can always manually open the file from Windows Explorer. The file is C:\Program Files\Solid Edge ST6\Program\ResDLLs\0009\testdrive_se2d.pdf
