When creating a new PMI section view in a model, the other section views turn off
I installed ST10 this week on two computers.  When creating section views in the model,I've run into an issue where the previous section views will turn off even though they are checked in the section view tree.  If I then click the main Section view check box and and on, they will all reappear.  I have been able to reproduce this on both computers.  I'll try to post a video of what happens.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
4 REPLIES 4
Re: When creating a new PMI section view in a model, the other section views turn off
Here's a Jing video showing the issue:
Note that after I click "cut all parts" both sections vanish.  They are in the tree, but unless you click on the main section view check box, they won't reappear.
https://www.screencast.com/t/mRFa5Bw4t
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
Hi @kjoiner
no this behaviour could not be reproduced here.
ST10 - MP01, Win10
I tried it within part and assembly and in both situations the PMI section worked as assumed.
Wolfgang
IR 9010202
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
GTAC was able to reproduce the problem in ST10.  Interestingly it's also reproducible in MP11 of ST9.  I never updated to that late of an update to ST9.  It's now PR 9010202
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
