When is the DATE Mainternance pack? ST9
It looks like there is a bug in the graphics ST9.
When is the Date coming Maintenance Pack?
12 REPLIES 12
Re: When is the DATE Mainternance pack? ST9
can you be more  specific about this bug, please?
What OS, graphics card and its drivers, etc.
MP are usually released after 1 or 1.5 month from original release and from previous MPs.
Ota
There is a known NVIDA graphics bug that was fixed in their latest driver...
http://Grundey.blogspot.com
Edge of win10 and seems to be compatibility issues.
Performance is better in Win7.
The problem seems not to graphics driver issues.
It looks at the problem of edge.
Can you post a pic of the graphics problem?  I've not noticed any.
What graphics card do you have?
Figure seem not at all.
Select the file open command!
It does not appear on the screen.
If this occurs, the edge is down
Currently we roll back to Windows 7.
My graphics card is a Quadro M4000.
Ram 32GB
ST9 on Windows 10.  Nvidia Quadro K2100M (latest driver).  No problem with Open form.
I use keyboard shortcuts?
What about preferences?
Installing the basic environment ST9 is not an error has occurred.
But changing environment setting value results in an error.
Andoeda it up sometimes ... ..
It is frustrating.
Everything is working good on Windows 10 in Solid Edge ST9.  It sounds like you have a problem with your PC.
Yeah ... I can not help.
Then let's test out the service pack again.
Thanks for your answer.
