When printing a drawing all shaded views do not show up in color
This may NOT be your particular issue, and some more info...
This may NOT be your particular issue, and some more information [what version & build of SE? / what OS & build?, etc.] might be needed before appying it...but check this similar topic... http://community.plm.automation.siemens.com/t5/Solid-Edge-Discussion-Forum/Shaded-views-in-draft-onl...
Solid Edge ST10 [MP7] Classic [x2 seats]
Re: This may NOT be your particular issue, and some more info...
We are using ST5 10 It is similar to that it is not the PDF we have problem with that will print color in all views. It is in the drawing that it will only print color in maybe one view.
That seems similar to what I was getting, albeit only in the PDF version, one shaded view when all were, and my drafts were multi sheet [typ 15-20] with 5+ views per sheet.
Might be worth a try.....if it changes nothing, just delete that registry key.
[caveat: only do this, if you're comfortable making registry edits...system damage may result otherwise]
Thank you this worked, has to wait for IT department to make the change.
