Where are the polygons hiding?
Not applicable
Hi all,
I've been looking and looking but can't find how in SE 2D one creates a multisided
polygon (like a six sided bolt head, for example.) What am I overlooking?
Cheers, Rick
3 REPLIES 3
Re: Where are the polygons hiding?
Not applicable
Rick,
That command is not currently available in 2D Drafting. It is high on the
list for enhancements.
Rick B.
Not applicable
"Rick B." wrote:
>Rick,
>Regards,
>Rick B.
just draw a circle in a "Construction" layer and then have lines with coincident
points and a load of "=" relationships.
Thats' how I used to do it, many moons ago!
-AS
www.continual-motion.com
Not applicable
If the APIs were turned on, you could use the VB macro that comes with Solid
Edge to create one.
If this is something you need often, create one in a Draft file by itself.
Then when needed, place it as a Symbol (geometry option) in your draft.
http://grundey.blogspot.com
"Andy Southern" wrote in message
news:4835958b$1@bbsnotes.ugs.com...
> "Rick B." wrote:
>>Rick,
>>Regards,
>>Rick B.
> coincident
> -AS
