Where is Drawing View Wizard
I am trying to place a drawing in my model tab into the page outline in my sheet tab.  All the instructions I can find tell me to use the View Wizard to scale the drawing.   I can't find a View Wizard in this program.
Re: Where is Drawing View Wizard
Esteemed Contributor
Hi there @53GHz,
Look on your Sketching tab, for a section called "Drawing Views"....use "2D Model" command....if you have model geometry, while on the working sheet where you want the view, you simply drag a window around your 2D model, for what you want to see in that view, and can select the scale at placement, or after the fact too.
Hope that helps.
Solid Edge ST10 [MP6] Classic [x2 seats]
Thanks Sean,
Unfortunately, Solid Edge Free 2D Drafting does not have a Sketching tab.    I resolved the issue by downloading the full version.
