Which software do you use for Electrical Schematics and Harness design?
Hello Edgers,
Solid Edge development would like to know which software do you use for Electrical Schematics and Harness design?
We would like to know the following -
  1. Which Electrical CAD (ECAD) software (Mentor - VeSys/Capital; Zuken - E3 Series etc.) are you using?
  2. Which version of ECAD software are you using?
  3. Does the ECAD software have an integration with Solid Edge harness?
  4. Do you use the output (connector and conductor list) from these software’s in Solid Edge harness? Is it sufficient or do you need enhancements in this?
  5. Do you use Solid Edge or other products for nailboard layout and downstream manufacturing information ?
Please reply here or direct message me with your responses.
Sandeep
