Why can I not download service packs. I have followed the correct steps and it tells me to narrow m
Your explanation is incomplete.  Please edit your initial...
Your explanation is incomplete.  Please edit your initial post to add the missing information.
http://Grundey.blogspot.com
Re: Your explanation is incomplete.  Please edit your initial...
Why can I not download service packs. I have followed the correct steps and it tells me to narrow my Search. Your search string resulted in more than 2000 matches. Please try to be more specific with your search string.
Return to FTP Server Top-Level This is the result of trying to download SP1, And SP2 for ST6. I followed the exact procedure from Dan Rubio. and it worked for him. Why is GTAC so painful to use?
It's not. You go to the download site and simply navigate the tree right to the correct service pack.
Open the following site: https://download.industrysoftware.automation.siemens.com/
In the Product Updates section, pick Solid Edge and select Go, then follow the tree to the correct version, product, bit type, and then SP#.
