Re: Why can't I change the 30.00 dimension?
(view in My Videos)
Done
Thanks for your effort. Since I can't see other viewpoints I can't tell if all the features ended up correct. But even if it did, and it probably did, I'm trying to create a strictly variable table driven part without the need to window anything or use the steering wheel to change it. I did finally succeed in that.
I did like your double window trick though. That's a new one for this sync novice.
Bruce Shand
(view in My Videos)
other view
Still can't see enough but it's ok because I got the variables to work. Thanks.
Bruce Shand
