Why can't I move my sketch profile in one direction whereas I can on the other one
I'm french and my english isn't good so appologize for approximations.
I'm new at SE and would like to know why can't I move the profile as I want using the link/bind tool (it works only on Y direction)?
Is there any other tool to move a profile ?
Thank you for your answers
Re: Why can't I move my sketch profile in one direction whereas I can on the other one
It looks like you have a horizontal/vertical relationship between your sketch and something on the model. Try deleting this and then you should be able to move your sketch.
It is a desired relationship.
It gives the good position of the profile on Y direction.
I would like to move the profile on X direction but whatever I do, the profile moves only on Y direction.
I still have tried your solution but my problem isn't solved.
TY for the answer
Seems like it should easily move in the X. Could you upload a video of your attempt?
Bruce Shand
Betreff: Why can't I move my sketch profile in one direction whereas I can on the other one
Hi @Supraim
agreeing with @bshand and @bweisenberger  with that horizontal realtion to the mid point of Your sketch line and the fixed dimension, only a movement in X is possible.
Now the question will be, how are You trying to move the sketch, maybe here the secret will be found.
Wolfgang
Hi @Supraim
and BTW I think tehre are to much relations on Your geometry anyway.
So many equal realtions where the are already equal with the horizontal and vertical relations.
My suggestion here will be to reduce it to an absoluteley minimum number of realtions to keep it fixed and fast
Here is what I mean:
Wolfgang
I'll reduce those relations
thank you for the tip
Hi @Supraim
great, but were You able to move the sketch now as You wanted?
Wolfgang
