Why can't I move parts in assembly anymore?
HI,
I screwed up my assembly somehow and most of the parts in the assembly "failed assembly relationships".
I want to assemble each part one by one but I can't even use the MOVE command becasue it is replaced by a REPLACE command now.
How can I move the parts now? I am using V18 by the way (I know, I know Smiley Sad )
Thnx
Re: Why can't I move parts in assembly anymore?
@Adkeep You are going to have to provide a bit more info about your issue.
Not understanding when you said that the Move command was switched to the Replace command.  They are 2 different commands...
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
Never mind. I fixed it. The MOVE command dissapeared but appeared back when I revised the assembly of one part.
