Why does Copy and Paste quit working?
For some reason, on some of my drawings, I loose the ability to copy and paste.  This makes the whole process take long with some of the more redundant drawings I have to do.  Any help?
Hi there,   Have you tried the obvious close out & restar...
Hi there,
Have you tried the obvious close out & restart Solid Edge to clear any memory [graphical & system] that may have been tied up. I have had this happen to me randomly also, but restarting SE had always worked for me.
Solid Edge ST10 [MP8] Classic [x3 seats]
Testing: Solid Edge 2019
Re: Hi there,   Have you tried the obvious close out
It works for a new document but if I save the one im working on, exit and shut down SE when I restart and open the drawing it stilk wont let me copy and paste.  This become really annoying when Im a third of the way through,  to far to start over fresh.
Sent from my Verizon Wireless 4G LTE Smartphone
Re: Hi there,   Have you tried the obvious close out & restar...
Not sure if this is it, but could it be a memory issue with the Draft getting so big and limited memory resources to be able to support the clipboard?
Production: ST10 MP7, Testing: SE 2019
http://Grundey.blogspot.com
Is there a way to clear the clipboard?
Found this.... http://www.tomstricks.com/how-to-create-a-desktop-shortcut-to-clear-the-clipboard-in-windows-7-or-in...
