Why does a part not display in assembly?
Created a SE part from a STEP file.
Trying to insert this part into an assembly - part does not appear on the screen.
Tried activating and showing hthis part - NG
Nothing appears on the screen
you imported part is most likely a construction body (sur...
you imported part is most likely a construction body (surfaces)
in assembly RMB the part then show/hide constructions - check on surfaces.
OR...
In part toggle from construction to design body or attach the construction thus making it design...
Matt Johnson
Application Engineer
Ally PLM Solutions
matt.johnson@allyplm.com
http://allyplm.com/
Re: you imported part is most likely a construction body (sur...
Hi Matt -
The part was a construction body and I was able to resolve this. Thanks for your quick and helpful response.
