Why my 'create part in place' button is grey
Need some help please -  The "create part in place" button turned grey while i was working in an aassembly file,
Can someone please tell me how to fix it?!
Thank you!
You may be in "Simplified Assembly" mode. Go to the Tools...
Community Manager
You may be in "Simplified Assembly" mode. Go to the Tools tab and change the radio button to "Design".
Dan Staples
Re: You may be in "Simplified Assembly" mode. Go to the Tools...
Actually I found out it is a bug in SolidEdge st4. You have to make create part from the library file, then it turns on back again. Thank you anyway!
'Tools' tab: 'Automatic update' must be on
