Wire passing through the parts (harness environment)
In the harness environment, I manually created a wire going from one part to another part of the machine. There are harness guides to help defining the path. However, it seems that the guides are not sufficient as the wire is still passing through some parts of the machine.
How can I avoid that ? Is it possible to "drag" the path, so that I can define more precisely the path ?
http://support.industrysoftware.automation.siemens.com/tr...
http://support.industrysoftware.automation.siemens.com/training/se/106/en_US/index.html#uid:wheditpa...
Production: ST10 MP7
Testing: SE 2019
http://Grundey.blogspot.com
