Wiring Harness
Is there a way to convert a wiring harness assembly to a flat layout, so I can create a draft?
5 REPLIES 5
Re: Wiring Harness
In Draft under the Diagram tab is the option to create a Nailboard of the 3D Wire Harness.
Kevin Grayson
Solid Edge Technical Consultant
kevin.grayson@siemens.com
Re: Wiring Harness
I was hoping there was a way to take the wiring harness from the assembly with curves and all, and straighten it out.
Re: Wiring Harness
I am wanting to straighten this out so I can throw a length dimension on it.
Re: Wiring Harness
Is that a wire created from Wire Harness or is that a stand-alone part file?
Kevin Grayson
Re: Wiring Harness
It was created in wire harness.
