With This Part Need To Split
Good Afternoon,
With this document I need to split in two, I've tried extrusion, move faces, in ordered part.
This is one part. I ran out of ideas!
http://screencast.com/t/QKmfMksSp
Thank You
Greg
From the highlighted portion in your video, it looks as t...
From the highlighted portion in your video, it looks as though to cutout has been done, but there seems to be a graphics hang on displaying the result. Try rebooting the PC to clear any/all of the memory [graphics & system] buffers.
Solid Edge ST10 [MP8] Classic [x2 seats]
Hi,   Could you share this model?   BR, Imics
BR,
Imics
Imics
Re: Hi, Could you share this model? BR, Imics
Good Afternoon,
What are your intentions?
Thank You
Greg
I would expect the intension is, to help you get a result....of course, you could use "private message" on this community to keep the item confidential.
Thanks Sean! Smiley Wink
Yes, we would like to help you, but it is hard without model.
BR,
Imics
Imics
Started to send the model, I noticed in the window by Q&A if I am to set to
User or Community
Thank You
Greg
Greg,
If you click on the users name you want to contact, you'll be directed to the "about" page for that user, and there is a link to the right side for sending that user a "private message".
Hmmm....just spotted that this method does NOT let you send attachments. You'd need to use a private file sharing site, [eg, Dropbox, or Hightail] then post the file link in your message.
