Wood (flat grain) fill pattern in Draft
I'm looking for a fill pattern for Wood (flat grain) rather than Wood (radial) in Draft. I've tried bringing one in from AutoCAD, but SE converts it to ANSI31(Iron). Any suggestions on importing from AutoCAD or creating a custom flat sawn wood grain hatch?
Re: Wood (flat grain) fill pattern in Draft
Look in Help...
https://docs.plm.automation.siemens.com/tdoc/se/108/help/#uid:index_styles:xid280112:chatch1h
Straight line hatches are easy, but things like your linear wood hatch are a bit more challenging.
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
Thanks Ken
