Workflow for assemblies in 2D solid edge,
Im trying to figure out a workflow for how to work with assembly drawings and then generate parts drawings on separate sheets. My first project I used blocks of each part and that works ok but makes the assembly look a bit messed up with extra lines etc.
Has anyone seen a good write up or tutorial on this?
Ulf
